Age Old Issue - BeoV 7/32 MKIII + Apple TV
This post has 23 Replies | 2 Followers
Mark
London
Posts 1,063
Mark Posted: Wed, Jul 31 2013 5:44 PM
Ok age old problem how to connect Apple TV to 7/32 MKIII.
Has anyone used a HDMI to SCART converter, does it work and do you loose any picture/sound quality.
And could you retrofit HDMI to this model TV
Also what is the best product you have found to clean the screen glass, 4 year old finger prints are a cleaners nightmare
Many thanks all
Millemissen
Flensborg, Denmark
Posts 14,680
I use this one on my old Avant:
http://www.amazon.co.uk/SCART-Converter-Adapter-quality-converter/dp/B007WRPJX2/ref=sr_1_1?ie=UTF8&qid=1375256463&sr=8-1&keywords=Hdmi+to+scart
Easy to set up - not the best picture, but it won't get better.
A compromise, but allows me to use the ATV in the linkroom.
bayerische
Ekenäs, Finland
Posts 4,770
Isn't there a DVI-input on the BV7 32"?
Too long to list....
Mark
London
Posts 1,063
Mark replied on Thu, Aug 1 2013 9:39 AM
Yes there is, but is my understanding on the DVI connection correct it only allows pictures not sound and I would have to install an Optical to Analogue converter for sound from the Apple TV.
Or would this route give me a better picture and sound quality ?
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Aug 1 2013 10:35 AM
For sure a better Picture AND digital Sound
Sound improvement:
depends on your Speaker set-up,
- if you use TVs Speakers only, Sound Quality is not an issue
- if you have a 5.1 set-up, via Scart this it is not possible to feed 5.1.
Ralf
HDMI / DVI = digital Signal with Resolution made for your tv (720p, 1080i etc.)
Scart = Lower Resolution, TV has to do upscaling...
Jonathan
Melbourne, Australia
Posts 1,811
Jonathan replied on Thu, Aug 1 2013 11:36 AM
So just to confirm, the DVI takes sound as well as picture? So all that is needed is a DVI -> Scart cable?
x:________________________
DMacri
United States
Posts 881
DMacri replied on Thu, Aug 1 2013 11:45 AM
No, DVI is for video only. It can't carry audio like HDMI does.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Chris Townsend
Qatar
Posts 3,531
No, I believe it effectively supplies the same image as HDMI but without the sound. That's always the balls ache problem. Trying to find a sound source!
StUrrock
Posts 995
Mark
London
Posts 1,063
Mark replied on Thu, Aug 1 2013 4:46 PM
interesting thread on Apple Community https://discussions.apple.com/thread/2611942?start=0&tstart=0 about the HD Fury
Mark
London
Posts 1,063
Mark replied on Sun, Aug 4 2013 9:45 AM
So I've ordered a Sounds Heavenly DVi to HDMI converter, a Lindy SPIDIF Digital to Analogue Audio Splitter and high quality leads.
I did a lot of research on the HD Fury and it seems you would still have a sound issue so defeats the cost (feel free to correct me on this)
Will give an update next week on how it went.
Question - Could you upgrade/retrofit HDMi to the BeoV 7/32 MKIII ?
Mark
London
Posts 1,063
Mark replied on Thu, Aug 8 2013 10:24 AM
All connected and working now and I must say I am rather impressed with the picture and sound quality when you take into consideration the the cabling and splitters involved.
What I like about doing such things and posting on this forum is what you learn, how boring if life was just all plug and go.
BeoHut
Posts 482
BeoHut replied on Thu, Aug 8 2013 10:58 AM
Hi Mark,
Good to know that this solution works. There are a lot of questions here on this forum about connecting Apple products to older Beovisions.
Thanks for sharing this solution with us and enjoy your upgraded setup! Hope it will do for the next few years.
Millemissen
Flensborg, Denmark
Posts 14,680
Note: the BV must be HD ready - otherweise this wouldn't work 'out of the box'.
I suppose a BC7-32 MK3 is!
BeoHut
Posts 482
BeoHut replied on Thu, Aug 8 2013 11:12 AM
Millemissen:
Correct Millemissen!
A good addition for the other members on this forum.
Jonathan
Posts 1,811
Jonathan replied on Thu, Aug 8 2013 12:42 PM
Mark:
Hi Mark,
Can you please explain how it is connected? I get the DVI to HDMi plug, but I'm not sure on the other one (do you have a link to where I could find one?).
Thanks very much
Jonathan
Posts 1,811
Jonathan replied on Thu, Aug 8 2013 12:44 PM
Oh, and the best way to clean is with either a microfiber cloth or a spectacles cleaning cloth. No water or solvents are necessary, just a little bit of elbow grease Yes - thumbs up
BeoHut
Posts 482
BeoHut replied on Thu, Aug 8 2013 1:13 PM
jldmelb:
What do you mean by this Jonathan in relation to this topic? Clean old age equipment?
Probably wrong post here ;-)
Jonathan
Posts 1,811
BeoHut:
jldmelb:
If you read the original question, the OP asks for the best way to clean fingerprints off the glass screen...
BeoHut
Posts 482
BeoHut replied on Thu, Aug 8 2013 1:29 PM
"Also what is the best product you have found to clean the screen glass, 4 year old finger prints are a cleaners nightmare"
Sorry Jonathan. Forgot this because I was fixing to the title (and so did others).
You are the first one who will come with this cleaning suggestion. Thanks!
Mark
London
Posts 1,063
Mark replied on Thu, Aug 8 2013 10:54 PM
Thanks J
Mark
London
Posts 1,063
Mark replied on Thu, Aug 8 2013 11:09 PM
Yes no problem.
Apple TV has an optical outlet for sound. I have connected this optical outlet via a TOSLINK cable to a LINDY SPDIF splitter (converts digital signal to analogue) and then L & R phono cable from this splitter to the AV4 connection on the TV (if you remove the rear panel that hides the connections their is a legend that shows you the placement of all the connectors).
I then went into TV SETUP, then OPTIONS, then CONNECTIONS, then AV4. Set source as PC, leave AUDIO and IR SOCKET to NONE and HDTV to DVI-I. I then added PC to my BEO4 remote which then allows me to quick access Apple TV.
Using my iPad I can then "throw" all my TV catch up etc to the BEO7.
Hope this helps.
Jonathan
Posts 1,811
Jonathan replied on Fri, Aug 9 2013 12:45 AM
Helps a lot! Thanks Mark
Barry Santini
New York
Posts 543
Beofan53:
Being in the optics industry, both precision and consumer, I felt very qualified to reach for many of the AR cleaners that had done me in good stead over the years for cleaning my BV9 screen.
Well, I was wrong.
The products and cloths I used didn't damage the screen, but they didn't result in an easy, streak-free shine either. Trial and error pointed to Monster Flat Screen cleaner. Both the cleaner and the specially-woven micro-fiber cloth are nonpareil for this job. I also use this kit to clean my BV8 and BS5.
FWIW
Barry
Page 1 of 1 (24 items) | RSS
