Beomaster 5: DLNA, UPnP, NAS compatible?
This post has 1 Reply | 2 Followers
TWG
Posts 1,672
TWG Posted: Tue, Apr 3 2012 10:27 AM
as there are many Systems out there I want to know if the Beomaster 5 is DLNA and/or UPnP compatible?
I want to access the Beomaster 5 via other UPnP or DLNA clients.
Does the Beomaster 5 has the ability to act like a NAS to offer access for other systems?
Hopefully somebody knows it :-)
mbee
Paris, France
Posts 1,842
mbee replied on Tue, Apr 3 2012 10:58 AM
The BM5 is DLNA compatible if you select "multimedia server" on the service menu.
But if you want to have full NAS functionnalities and good reliability, I would suggest to go for a (at least) a dual drive NAS (from QNAP or Synology) in RAID, in order to have a backup of the data in case of disk failure. Then you can add a BS5 or BS5E to this bulletproof database (if its only for some multimedia files, the BM5 is sufficient, but for important datas, a good NAS is mandatory.
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
