Hinge BC7XXX wanted
BO
Halmstad, Sweden
Posts 728
BO Posted: Tue, Aug 13 2013 7:57 PM
Right side hinge for a Beocenter 7700 wanted.
Same part in BC 7700, 7007, 7002, 7000 & 5000
Part no 2040 in picture.
//Bo.
A long list...
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Wed, Aug 14 2013 8:12 AM
I posted a request for one about a year ago, with no response. I've been looking ever since.
If you find two :-) or come up with a way to make them, please let me know.
/  Johan
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Aug 14 2013 4:45 PM
The Beocenter 7000, 7002, 7007, 7700 aluminium cover right side hinge is very often found broken.
I' ve had good success with cleaning and roughening up the remains and the track in which it sits in the aluminium
plate with sandpaper and/or a file and then a good and strong epoxy (Araldite) to fix it all in place.
With good skills and a finishing drop of black paint the repair will be almost invisible.
This part breaks because the user forced the lid closed too fast and the dampening (Kilopoise-) grease
on this part and its counterpart had hardened to some extent.
Tip: The kilopoise grease is a sticky and stubborn substance but will dissolve and wipe off easily
if you give it a shot of contact cleaner (Contact 60 or 61, De-oxit etc.).
If you add new grease then only sparingly.
Dave Farr
France
Posts 2,283
Dave Farr replied on Wed, Aug 14 2013 7:14 PM
Isn't member ALF parting out a BC7000?
Dave.
BO
Halmstad, Sweden
Posts 728
BO replied on Thu, Aug 15 2013 11:08 AM
Thanks for the advice Martin.
//Bo.
A long list...
Johan
Uppsala, Sweden
Posts 239
Silver Member
Johan replied on Thu, Aug 15 2013 12:23 PM
Thanks! I'll probably try that when I get around to overhauling my 7700.
/  Johan
Page 1 of 1 (6 items) | RSS
