Hi
I am looking to replace a resistor in my B&O but seems hard to find.
it is a 10 ohms 10% 0.30w (stated in service manual)
Checked ebay but mainly 5% resistors to sell.
Someone on this with cheap shipping fees.
Country of delivery = France
or do you guys use replacements.... like 10 ohms 5% 1/4w
The percentage spec is merely the tolerance.A 10 Ohm 5% resistor is guaranteed to be closer to 10 Ohm than a 10% so wouldbe a fine replacement.Is this in a Beocord 5000 power supply ? If it is, the resistor should be a fusible type and in this case PM me.
Hi Martin
Thank you for your reply, it's for beolab 2500. I will order 5% resistor then.
Anything to change on these beolab 2500 while they are open ???
Why do you need to replace this resistor ?If it burned, there will be a reason that will have to be investigated.
I know, for now I just order resistors as I am very very poor in these.
Changing resistors does not happen very often, Just on a beocenter 2300 once I changed one, if I remember it was a problem with the sliding doors.
I ordered a set on E...y
Somthing like 90 kinds and 2250 resistors. Will see...
