Resistor
chti59
France
Posts 149
chti59 Posted: Sun, Aug 18 2013 12:29 PM
Hi
I am looking to replace a resistor in my B&O but seems hard to find.
it is a 10 ohms 10% 0.30w (stated in service manual)
Checked ebay but mainly 5% resistors to sell.
Someone on this with cheap shipping fees.
Country of delivery = France
or do you guys use replacements.... like 10 ohms 5% 1/4w
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Aug 18 2013 1:13 PM
The percentage spec is merely the tolerance.
A 10 Ohm 5% resistor is guaranteed to be closer to 10 Ohm than a 10% so would
be a fine replacement.
Is this in a Beocord 5000 power supply ? If it is, the resistor should be a fusible type and in this case PM me.
chti59
France
Posts 149
chti59 replied on Wed, Aug 28 2013 7:09 AM
Hi Martin
Thank you for your reply, it's for beolab 2500. I will order 5% resistor then.
Anything to change on these beolab 2500 while they are open ???
Dillen
Posts 13,191
Dillen replied on Wed, Aug 28 2013 11:41 AM
Why do you need to replace this resistor ?
If it burned, there will be a reason that will have to be investigated.
chti59
France
Posts 149
chti59 replied on Thu, Aug 29 2013 10:12 AM
Hi Martin
I know, for now I just order resistors as I am very very poor in these.
Changing resistors does not happen very often, Just on a beocenter 2300 once I changed one, if I remember it was a problem with the sliding doors.
I ordered a set on  E...y
Somthing like 90 kinds and 2250 resistors. Will see...
Page 1 of 1 (5 items) | RSS
