Connecting Beolab 5000 to headphones
This post has 7 Replies | 0 Followers
fergus
Posts 78
Silver Member
fergus Posted: Wed, Aug 21 2013 10:03 PM
Hello
Is there any way to connect the Beolab 5000 to headphones apart from the stereo width box?
Can you use the second set of speaker outputs to connect to a headphone pre-amp or amplifier?
Any recommended pre-amp/amplifier/ohm/voltage...?
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Aug 21 2013 11:11 PM
The reason you cannot use headphones normally is because the channels have reversed polarity - that is why you need the stereo width box. Not sure what a headphone amplifier would do. What about the tape out connections?
Peter
fergus
Posts 78
Silver Member
fergus replied on Thu, Aug 22 2013 7:35 AM
Thanks Peter. I'm not sure about using the tape out and I wouldn't like to try it without knowing it won't break something. Maybe someone else has tried this?
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Aug 22 2013 7:56 AM
Tape out will be perfectly adequate!
Jacques
fergus
Posts 78
Silver Member
fergus replied on Thu, Aug 22 2013 9:27 PM
Tape Out to a headphone amp?
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Aug 22 2013 10:19 PM
fergus:
Indeed, yes.
Jacques
Peter
Earsdon
Posts 11,991
Peter replied on Thu, Aug 22 2013 11:30 PM
Tape out will give line out which the headphone amplifier can then amplify to the level you want. The tape out comes out before the power amplifier of the Beolab 5000. The 5000 has a clever circuit so that the two speaker outputs are in opposite phases which allows better ability to deal with power demands - have a look at the service manual - unusually for B&O, it is very informative!
Peter
fergus
Posts 78
Silver Member
fergus replied on Fri, Aug 23 2013 7:40 AM
Excellent! Thanks a lot everyone.
Page 1 of 1 (8 items) | RSS
