Beogram 4002 (5524)
This post has 3 Replies | 0 Followers
Richard Gearing
England
Posts 25
Richard Gearing Posted: Thu, Aug 22 2013 1:23 PM
Hi, advice needed. I'm trying to rebuild a Beogram 4002. The small pulley wheel on the end of the brass lead screw has a split centre, so cannot be secured properly. Has anyone repaired the fixing or know of a modern replacement? Thanks
Richard Gearing
England
Posts 25
Hi, I've found that a slightly modified meccano pulley works very well, at least until I find an original. All the best Richard
Peter
Earsdon
Posts 11,991
Peter replied on Tue, Sep 17 2013 4:12 PM
Well done! The problem with these is that there a number of different sizes - the hole in the middle can be different sizes! I was sent one by a friend that didn't fit - I repaired my original instead.
Peter
Orava
Finland
Posts 991
Orava replied on Wed, Sep 18 2013 8:36 AM
It should be lego Big Smile
Page 1 of 1 (4 items) | RSS
