Hi my phone's display has gone blank following me being in the garden yesterday and the phone off the base.When I call my landline from my mobile it rings but no display at all. Can any one help?
Are you saying it's only the display at fault? When you call the phone and it rings, can you answer the call? Can you make outgoing calls on it? Is there a dial tone?
Did you drop it or did it in any other way experience a strong force?
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Based on your fault description, I would say that either screen itself has become faulty or more likely the small rubber strip connecting the screen to the PCB is not making connection any more.
Regards Keith....
