Remove surround
This post has 5 Replies | 0 Followers
bramble
Posts 397
bramble Posted: Tue, Aug 27 2013 3:31 PM
 Maybe some of you folks out there can help......how do you remove the surround from a beovision 5 as I want to clean the speaker cover, hope someone can help as I don't want to push/pull the wrong way and knowing b&o there will be some  simple way
Rgds
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Tayne
Posts 38
Tayne replied on Tue, Aug 27 2013 3:44 PM
It actually just pulls away and then clips back. It is very tight though so I can see why someone would think it is fixed in another way.
olvisab
Posts 1,391
olvisab replied on Tue, Aug 27 2013 3:49 PM
It is so tight that I never thought it can be removed like this. Are you sure ?
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
bramble
Posts 397
bramble replied on Tue, Aug 27 2013 4:45 PM
It's a bit off grey area......as don't want to damage it! Should you use anything to tease it of?
bramble
Posts 397
bramble replied on Tue, Aug 27 2013 5:19 PM
Thanks folks, just take it easy and pry with butter knife and a cloth (to stop any unwanted scratch marks) and it just pops off, just watch for the small wire at base behind surround , bv5 all happy and dust and grim freeBig Smile
bramble
Posts 397
Page 1 of 1 (6 items) | RSS
