Maybe some of you folks out there can help......how do you remove the surround from a beovision 5 as I want to clean the speaker cover, hope someone can help as I don't want to push/pull the wrong way and knowing b&o there will be some simple way
Rgds
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
It actually just pulls away and then clips back. It is very tight though so I can see why someone would think it is fixed in another way.
It is so tight that I never thought it can be removed like this. Are you sure ?
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
It's a bit off grey area......as don't want to damage it! Should you use anything to tease it of?
Thanks folks, just take it easy and pry with butter knife and a cloth (to stop any unwanted scratch marks) and it just pops off, just watch for the small wire at base behind surround , bv5 all happy and dust and grim free
