Hi Räuber,
I use a BV10 in the bedroom as a link tv. Now i am only using Audio from the main room. Before moving i used audio link and distributed video through RF from my BV9.
What is your problem?
I can confirm your opservations partly. When I switch from Audio to Video Source the Audio system stays on, but not the other way round. It happens not only on my bv10 but also on the main room bv9.
I have no speakers connected to my BS2500. I suspect the Beolink 1611 to be the Problem, which does the connection from the BS2500 to Masterink in my setup.
Greetings
Yesterday I asked my technician to update my BV 10-40 again with the latest software. It's Build 229, I had Build 227 installed.
Although the technician had no information that the described bug was solved, with Bulid 229 the bug is gone! No more faults when using BV 10-40 as a link TV (V.OPT = 6) and switching from a video to an audio source in main room (or the other way round).
So it took more than 4 years until the software engineers had solved this software bug!
Regards
Räuber
