Replacement fret for BeoVision 5
beojeff
USA
Posts 2,012
beojeff Posted: Mon, Sep 9 2013 10:04 PM
Does anyone know if replacement frets for the BeoVision 5 can still be obtained? If not, perhaps suggestions for places that might have salvaged one from a dead BeoVision 5? Or perhaps a suggestion for a place that might be able to replace the fabric with an appropriate speaker fabric? I currently have a silver fret but would like to replace it with a black fret.
BeoMegaMan
Posts 601
There aren't any available from the factory any longer, but if you call around some dealers may still have some lying around.
Ah, you know... A little B&O here, a little there
Razlaw
Posts 4,345
Razlaw replied on Mon, Sep 9 2013 10:26 PM
I was able to order a Beovision 5 fret a little less than 3 years ago. (And then took the cloth off of it and recovered my BV10 fret with it to match my Beolab 1s) glad I did that when I did if they are no longer available.
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Mon, Sep 9 2013 10:30 PM
Just did reclothing a Beovision 5 this weekend in a beautiful aluminium fabric look. My BV5 has a silver frame and I have another one with a black frame. We're talking about the plasma right?
Brengen & Ophalen
beojeff
USA
Posts 2,012
beojeff replied on Mon, Sep 9 2013 10:54 PM
Leslie:
Yes. The plasma. How difficult was the reclothing? Could you provide some advise on how you did it? Where did you source the appropriate cloth? I wonder if B&O might sell the black speaker cloth so that it matches the other black speaker frets, such as on the BeoLab 8000, etc.?
BTW, my fret is silver if anyone has a black one they would like to swap.
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Sep 9 2013 11:03 PM
Quite easy, the shape is squared or rectangled so reclothing should not be that difficult. The worst part is that the fret consist of two parts which has been both attached with double sided tape. With some patience you're able to take them apart. Regarding the cloth, I purchased black cloth from Ebay Germany which has almost the same feels and looks like the BL8000. But I have to look which seller that was. Bought fabric from several suppliers...
Brengen & Ophalen
butch1
Posts 384
butch1 replied on Tue, Sep 10 2013 12:35 AM
Contact Darren at timeless av he recovers them.
dontfret
Posts 2
dontfret replied on Mon, Sep 16 2013 11:30 AM
dontfret@hotmail.co.uk offer fret refurbishment
Page 1 of 1 (8 items) | RSS
