Good morning everyone.
I wonder if anyone can help me with this. I want to connect and play my ipod through my beovision7.32. I assume I can do this using the red, white, yellow pin sockets on the side on the tv set but the connection is not automatic. I guess there must be a set up somewhere to tell the tv set to read the ipod. Other items I plug into the same sockets seem to work ok like a Wii unit for example.
Any ideas would be welcome.
I would presume you need to press [CAMERA], or (bad news) you need a proper video signal to wake-up the connection
BeoNut since '75
A Wii (or any other video device) will auto switch the TV to CAMERA. However, the audio signal alone will not.
Add CAMERA to your Beo 4 by pressing STANDBY (red dot) and LIST together. Select ADD?, then scroll through the list until CAMERA is shown. Press GO to add CAMERA to the LIST button on your remote.
Now, when you wish to listen to your iPod, hit LIST on your Beo 4 until CAMERA is displayed on the screen of the remote. Then press GO and you should be able to hear your music....
Thank you very much, that has done the trick.
