Hi all,
I know this has been asked but for the life of me I cannot find it.
Can someone tell me how to remove the Glass doors for cleaning for a Beosound 3000.
Thank you
Stuart.
Open doors, disconnect power plug, With your fingers, pull straight out at the arrows, lower side first then the upper, dont loose them.
The doors are just hooked into the brackets with these pressure taps
Thank you.
That is an excellent explanation.
This will make it so much easier.
Thanks again Soren.
Stuartk1164: Thank you. That is an excellent explanation. Stuart.
I know
