Removing Doors for Cleaning
This post has 5 Replies | 0 Followers
Stuartk1164
Posts 6
Silver Member
Stuartk1164 Posted: Fri, Apr 6 2012 11:15 PM
Hi all,
I know this has been asked but for the life of me I cannot find it.
Can someone tell me how to remove the Glass doors for cleaning for a Beosound 3000.
Thank you
Stuart.
Søren Mexico
Mexico City
Posts 6,411
Open doors, disconnect power plug, With your fingers, pull straight out at the arrows, lower side first then the upper, dont loose them.
Søren Mexico
Mexico City
Posts 6,411
The doors are just hooked into the brackets with these pressure taps
Stuartk1164
Posts 6
Silver Member
Thank you.
That is an excellent explanation.
Stuart.
Stuartk1164
Posts 6
Silver Member
This will make it so much easier.
Thanks again Soren.
Stuart.
Søren Mexico
Mexico City
Posts 6,411
Stuartk1164:
Thank you.
Stuart.
I know Whistle
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
