thanks.
I can have the beocenter AV 9000 and his center speaker with the master panel for a few €, a bargain, but since I have no use of the TV set, I would like to use the master panel as stand alone music center and timer in our bedroom.
I can also sell it back, but no ideas of its value. maybe as you mention it a simple active kit, but look a bit overkill just to wake up in the morning.
kai:Yes you can do this I have done it and it still going after 10 years it's not cheap to do, it might better to get a used overture they are quest cheap now other alternative could be an active kit speakers plugged into that and ir sensor.
Please explain how you managed to do that?
Brengen & Ophalen
Ok, so you did more modifications to make it works as an Ouverture.
