Beomaster 6000
This post has 12 Replies | 1 Follower
Mercian
Posts 5
Mercian Posted: Sat, Oct 5 2013 12:47 PM
Hi everybody, I have a system which includes a Beomaster 6000 . I like the way you can apparently flip the front for servicing ( the tuning belt needs attention ).... But .er.. ahem... how do I do it ?. All I can see is a small aperture on the side and two hex heads on the top rear. I'd guess there's a catch release via the aperture but I don't like going by guesswork and poking things through holes on the offchance. Any advice would be welcome. Thanks, Roger.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 5 2013 2:07 PM
Welcome to Beoworld!
If you have an 80's Beomaster 6000 (but then no dial cord [edit: of course there is a dialing string] or belt here, just a belt for the motorized volume pot) it's easy, you have to unscrew the hex screws between the fins and the alu/glass panels and that's pretty much it, the whole top will happily flip over!
Click on the picture.
Jacques
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Oct 5 2013 2:34 PM
The Beomaster 6000 actually has a tuning string. Not a belt, but a real dial string.
What Jacques shows you is the correct way of getting in.
Mercian
Posts 5
Mercian replied on Sat, Oct 5 2013 2:41 PM
Thank you Jacques , It's a Type 2252 , Ser number 3228001. It's making the groaning sound which stops when the up / down arrows are pressed . I read that its the belt slipping as it attempts to return to its position. However it appears to have been in storage for some time ( slight damp - garage or similar) together with a Bg 6002 and a Bc 8004 , they were a bit grimy and I wasn't expecting too much, but they're cleaning up nicely with few signs of wear, led panels, turntable operation etc all seem ok ( the leads weren't present so I cant test actual function ) I've just downloaded the Service manual for the BM 6000 so I'll open it up for a visual inspection. Once again, many thanks for your reply. - Roger.
Mercian
Posts 5
Mercian replied on Sat, Oct 5 2013 2:53 PM
Ah, I see, thanks Dillen . I'm hoping that it's just a few aches and pains because it's been stored in less than perfect conditions. I'll have a better idea when I open it up .... tomorrow I hope .
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Oct 5 2013 7:52 PM
Mercian:
Do keep us informed!
These are quite easy to work on, being cleverly put together. The Beomaster 6000 actually uses the same chassis as that of the contemporary Beocords, if you look closely!
Yes the groaning sound is the volume belt indeed. Martin, by the way, has the adequate belt. But you probably already know that...
Jacques
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Sat, Oct 5 2013 8:06 PM
This would be a challenge for me to check my own BM6000 but it looks quite complicated to open it, or not?
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Oct 5 2013 8:09 PM
Oops, sorry I thought you guys were talking about the 4ch BM6000.
But I have this one as well that's going to be serviced by my own tech man.
Brengen & Ophalen
Mercian
Posts 5
Mercian replied on Sun, Oct 6 2013 9:13 PM
Well Jacques , I've had a look and the good news is it seems to be an honest machine. IC5 on board 6 has either been resoldered or replaced at some point but apart from that there's no sign that anyones been in there. You were right , the volume belt does need replacing , it looked very tired and a brown film covered it . I cleaned the belt and gently worked the pulleys manually and while it now works it still grumbles now and again. Did you say Martin has them , I'm new , how do I contact him ?.. I also had a quick look inside the Beocord , as you would expect the drive belt was now a strip of sticky licorice . One of the wires soldered to the spring contacts at the rear of the cassette carrier had sheared off , not surprising as it flexes every time it's operated . As I've said the leads didn't come with these , I have a 6500 system which I bought last year , i dont know if the leads are compatible I'll have to check . Anyway play stopped there , a lovely sunny day and an apple tree that needed stripping intervened . Thanks and bye for now.
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Oct 6 2013 9:40 PM
Good job so far!
Martin is none other than Dillen who answered you here!
Send him a Private Message (PM) by clicking on his alias!
He will also supply the Beocord belts.
Jacques
Anders Jørgensen
Denmark
Posts 350
The white BM6000 presented above in open position is still mine and working great. That actual picture was taken in 2008. Dillen saved the burned powersupply and other small things + supplied the remote printboard which were never installed before.
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 7 2013 7:20 AM
Oh! I downloaded this in 2009, it was still in my Beomaster 6000 folder. Sorry!
Glad to know it works like a charm!
Jacques
Mercian
Posts 5
Mercian replied on Tue, Oct 8 2013 9:30 AM
On closer inspection the amount of lateral movement between the drive shaft and the reduction box is not good. Fitting a new belt at the moment would be pointless I'm afraid , putting even more strain on the box and likely killing the motor itself. As I say, not good.
Page 1 of 1 (13 items) | RSS
