Hello everyone, I have bought a Beocom 6000 to go with my Beocom 2 and BeoLine PSTN Base, and I'm not sure if it is compatible.
I am not sure if these are compatible as I cannot get the Beocom 6000 to see the PSTN or am I just doing something wrong? Any help would be gratefully appreciated.
Regards
Tarx
I think only the MK1's are only compatible with the MK1 PSTN Base, you will need a MK2 PSTN for MK2 phones to work.
So basically if you have MK1 phones and your PSTN Base is MK2 then it will not work as I understand it. If you have MK2 phones then it should not matter, if you have 1 x MK1 & 1x MK 2 then you need a PSTN Base MK1, and if you have the right equipment then maybe you PSTN Base is faulty? Might be worth popping into your nearest B&O with your phones and PSTN so that can check them.
Hope that helps.
This may also help: https://www.beoworld.org/faq_view.asp?id=74
