Buzzing Beomaster 6500
This post has 11 Replies | 0 Followers
cmsammy
Posts 84
cmsammy Posted: Mon, Oct 7 2013 12:03 PM
Anyone know what would cause my amp to buzz even in standby, the sound is perfect, it's the unit buzzing and it makes no difference what input is selected when it is powered on. It's annoying because I can't leave it plugged in.
My guess is the power supply but which bit of it ?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Oct 7 2013 1:52 PM
The transformer.
It's a common issue and the only fix is to find a replacement trransformer that doesn't buzz from
a donor unit.
cmsammy
Posts 84
cmsammy replied on Mon, Oct 7 2013 4:10 PM
Guessed as much, I work in security and the 12v transformers we use often end up doing this, cheers Martin
tournedos
Finland
Posts 7,357
The surface that the Beomaster is sitting on can amplify the noise a lot. Try locating it on some different furniture and it might quiet down enough to be bearable. Soft rubber feet can work wonders too.
--mika
Peter
Earsdon
Posts 11,991
Peter replied on Mon, Oct 7 2013 5:10 PM
Agree - the surface can resonate with the transformer - it does depend how sensitive you are to this sort of noise. Martin's advice is clearly the ultimate but worth trying two squash balls cut in half as legs - used this on a Beomaster 3000 that was unbearable but was fine when suspended!
Peter
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Oct 28 2013 4:41 PM
You can also make custom absorbers very easily with bathroom silicone that you can cast to your liking! Silicone is very effective too, and much cheaper than audiofool sorbothane stuff Big Smile
Jacques
Die_Bogener
Posts 192
There are 8 soft plastic bearings used for the transformer. They can go defect, become hard and break. Or become lose bolts. Replace them, they are still available and B&O Standard parts.
If it is the transformer itself that makes this noise, there is a Special spray available, called "Plastic", something very similar to a clear coat for car paint, but for electronics. The transformer get's sprayed with this clear coat, fixing the coils to the core.
Humming gone... Big Smile
Christian Christensen
Stockholm
Posts 512
Not a unique B&O issue, its a common issue I run into with different audio equipment, no matter of brand. And the fenomen is unlogical, it can appear,and couple of month disapear.
My re-capped M75 are my precious diamonds.
js
Posts 382
Die_Bogener:
Hi Die_Bogener,
I am looking for this spray as I have the same hum issue. Can you confirm which spray you are exactly referring to? A google search resulted in the attached image, but I am not sure this is the one.
Many thanks ! Smile
Die_Bogener
Posts 192
Yes, this spray will work for the transformer.
Diasassemble the transformer from the master and spray it several times from both sides. Let the material work inside the coils, it must penetrate the coils.
js
Posts 382
js replied on Mon, Aug 31 2015 2:26 PM
Many thanks Die_Bogener, much appreciated  Smile
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Jan 12 2016 1:28 PM
Just as a help to others, I also now had issues with a humming BM7000.
I had some hot-glue strips 11mm width lying around, and I decided to try to see what happened if I cut 8 pieces of 3mm thick, and drilled a 5mm hole in them, and then replaced the old dry and crackled bushings with these new "rubber" bushings...
95% of the buzzing is now gone... :)
I don't know what the long term effect will be, but I hardly think that they will melt, even though the BM gets quite warm during periods of "loud playing" :)
Maybe if I used the plastic spray, I could get the buzz totally gone, but I will try to see if this is enough for me.
So far I am very happy with the lack of buzz ;)
/Weebyx
Page 1 of 1 (12 items) | RSS
