Beolit 12 dead ?!?
plumber77
Posts 76
plumber77 Posted: Tue, Oct 8 2013 7:22 PM
Nothing. Will not respond to any of the buttons on the top.
On charge for an hour now still nothing.
Lead and fuse are both OK.
Any ideas???
BeoMegaMan
Posts 601
Most likely a faulty battery issue. Simply take it to a dealer for a replacement provided your under warranty still.
Ah, you know... A little B&O here, a little there
plumber77
Posts 76
Thanks for the reply.
I got it from B+O direct in June. I have contacted them and am awaiting a response but just wondering if there is something I was missing!
Flere
Netherlands
Posts 345
Flere replied on Wed, Oct 9 2013 11:26 PM
Die you try putting your finger on the on/off button for more than 1 minute?
When I use my Beo4 for light control the Beolit12 crashes sometimes. Toen the above trick helps me to reboot the basket.
Flere
- Flere
smile and enjoy the moment
Page 1 of 1 (4 items) | RSS
