Nothing. Will not respond to any of the buttons on the top.
On charge for an hour now still nothing.
Lead and fuse are both OK.
Any ideas???
Most likely a faulty battery issue. Simply take it to a dealer for a replacement provided your under warranty still.
Ah, you know... A little B&O here, a little there
Thanks for the reply.
I got it from B+O direct in June. I have contacted them and am awaiting a response but just wondering if there is something I was missing!
- Flere
smile and enjoy the moment
