Is it possible to disable the loading function of the BC2, ideally deactivating / reactivating it with the Beo4?
I'd like to be able to switch-off the door opening to prevent the mechanism being wrecked by adventurous little fingers. Unplugging the unit is too messy and also involves use of the PIN on reconnection.
Graham
Thanks Ralf!
