Beocenter 2: disabling opening function?
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger Posted: Mon, Apr 9 2012 10:53 AM
Is it possible to disable the loading function of the BC2, ideally deactivating / reactivating it with the Beo4?
I'd like to be able to switch-off the door opening to prevent the mechanism being wrecked by adventurous little fingers. Unplugging the unit is too messy and also involves use of the PIN on reconnection.
Graham
mauszwerg
Posts 104
Hello vikinger,
there is a simple way to lock the loader with your BEO4 remote : With the BC2 turned on, press “menu” then press "fast forward" and within 3 sec. Press 0 0 GO. This opens the service menu. topic number 7 is lock/unlock.
You can find detailed information in the service manual part 3 here on the site.
Ralf
vikinger
Posts 5,422
vikinger replied on Mon, Apr 9 2012 10:09 PM
Thanks Ralf!
Graham
Page 1 of 1 (3 items) | RSS
