Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
There are several combinations of Sky HD box meaning some remotes will not work with some boxes.
Assuming your Sky HD box is not an early model, then the attached XML file should work.
Extract the XML file to C:\ and it will be placed automatically into the correct directory of the Configuration Tool
Let us know if it works for you..
Regards Keith....
Chris,
To date I have come across about six different combinations.
Attached is one for the Sky Amstrad version which may work.
Hi Keith, Thanks for the above file. This seems to work so far - power and guide and then the Beo5 died. Everytime I seem to sync with the computer it kills the battery. So on charge and will report back later.
Both of the XML files I provided uses Philips RC6 20 bit protocol, however the DRX-895-C uses a device code of 0 and the other XML uses a device code of 5
Why Sky decided to use different device codes I do not know, but they did.
Any XML files attached to posting from me and others can be freely used.
