Beocentre not working
Derek
Posts 2
Derek Posted: Sun, Oct 20 2013 12:21 PM
Anyone able to tell me what I should do. Unit is displaying CO.dE
is here a code I need to input, if so how
thanks
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Oct 20 2013 12:28 PM
Derek,
more information needed.  Which Beocenter?, where did you buy it?
Looks like you need to enter a PIN code which you should have been given by the seller.
Dave.
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Oct 20 2013 3:50 PM
If it's a BC9500 then the answer may be in the sites FAQs as follows:
This usually happens if you have replaced the S/W or the lithium battery has been replaced or needs replacing.
Fix the battery or RAM and then:
Using a Beolink 1000 press:1271
After 3 seconds, disconnect the 9500 from the mains and then reconnect. - Done!
Derek
Posts 2
Derek replied on Mon, Oct 21 2013 2:10 PM
Thanks Guy, could you let me know where the Lithium battery is accessed please
Derek
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Oct 21 2013 6:02 PM
If you open it up it's bottom right of the main PCB when view from the front. I think it is under some sort of cover and that you have to resolder it.  I have never done this myself but am sure others can advise.
I'll post a photo tomorrow from work. Only have nexus at the moment and struggling to add picture!
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Oct 22 2013 6:03 AM
As promised - the battery is in the red circle!
Page 1 of 1 (6 items) | RSS
