Masterlink Gateway
This post has 12 Replies | 2 Followers
m4spm
Posts 12
m4spm Posted: Mon, Oct 21 2013 10:15 AM
I am looking at buying a 2nd hand Masterlink Gateway. Have different models been produced over the years or is there just one version?
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Oct 21 2013 12:29 PM
Ikatu made the MLGW for Beo. They first produced the MLGW 01.
Since year 2009 the MLGW 02 is in production. There was no further hardware change, but you can update your MLGW via internet for new features like camera view and 2 way communication for N.MUSIC in Beolink app.
More info: http://ikatu.com/en/rnd/mlgw
And: http://mlgw.bang-olufsen.dk/
Hope this helps
Stefan
spezializten
Posts 67
Hi!
I might have one extra for sale. Interested?
Regards Björn
m4spm
Posts 12
m4spm replied on Sat, Oct 26 2013 7:17 AM
Thanks for the info. So would type 1701 be a Mk 2?
m4spm
Posts 12
m4spm replied on Sat, Oct 26 2013 7:26 AM
I have seen one in a shop in the UK at a very good price! depends what price you would want. Thanks
stefan
Posts 2,920
stefan replied on Sat, Oct 26 2013 1:35 PM
m4spm:
Yes, I think so. 1701 is mentioned in the latest pricelist from June 2013.
Although my MLGW is typenumber 1798/1799...??
Stefan
beojeff
USA
Posts 2,012
beojeff replied on Wed, Dec 4 2013 12:41 AM
What are the differences between version 1 and version 2? What can version 2 do that version 1 cannot? Can version 1 still receive the same firmware updates as version 2?
stefan
Posts 2,920
stefan replied on Wed, Dec 4 2013 2:03 PM
From ikatu site:
"Masterlink Gateway MK1: RS232 home automation interface to Beolink products for the US market."
And:
"Masterlink Gateway MK2: Ethernet and RS232 home automation interface to Beolink products. Global product".
So, MKII replaced MKI as a global device with additional ethernet socket. I don`t think that MKI will be still supported.
Stefan
beojeff
USA
Posts 2,012
beojeff replied on Wed, Dec 4 2013 2:54 PM
It stil isn't clear whether the MK1 is compatible with the BeoLink App and with the 2-way control of the BeoSound 5.
BeoMegaMan
Posts 601
Seeing as the MK1 only has RS-232 and ML, I would say that no it won't support the BeoLink App or Two-Way.
Ah, you know... A little B&O here, a little there
spezializten
Posts 67
I have a 2nd hand Masterlink Gateway for sale. Are you still intrested?
/Björn
TWG
Posts 1,672
TWG replied on Sat, Oct 20 2018 3:26 PM
It's a very old thread, I know... but does somebody know the differences between MLGW 1701 and MLGW 1799?
kallasr
Germany
Posts 2,562
kallasr replied on Fri, May 15 2020 6:00 AM
No differences. A Type Nr. 1799 has Ethernet as does the Type Nr. 1701, so both are MK II.
We used a MLGW 1799 for the integration of a Beosound 5/Beomaster 5 with the Beolink 2 App. You can browse the library on the hard disk for example, so 2 way functionality.
Ralf
Page 1 of 1 (13 items) | RSS
