Hi there,
Can anyone suggest a non Bang and Olufsen subwoofer for my Beosound Overture. I have been looking at the B and W ASW600 but really have no idea what will match.
My understanding is that it is not so much which sub will match your stereo, but which sub will much your speakers best (yet none have been identified.) Pray tell!
KingOfSnake: My understanding is that it is not so much which sub will match your stereo, but which sub will much your speakers best (yet none have been identified.) Pray tell!
Even more still - match the listening space!
Welcome to BeoWorld brwardle,
We would like to hear more information about your system and room. We can probably help you better with such details.
Beo4 'til I die!
The speakers are Beolab 2500. Thanks
The room is approximately 15m x 7m, carpet, one wall mostly glass as we have have double sliding doors, walls are made from plasterboard. I listen to a wide range of music and need to know what sized sub would suit, what design as i hear there are many, down firing, ported and non ported etc. Finally if there is a brand you reccomend, and can you comment on the B and W ASW600 and ASW1000. Thank you!!
