You can control 99% of 3rd party products with the Beo5.
The best way of getting the IR codes for your required 3rd party products is by capturing them from your original 3rd party remote control.
If you wish to control w third party product it is reasonable to assume you have the original remote.
The challenge is then to create an XML control file with these IR codes which is understood by the B&O Control file.
If you cannot capture the required IR codes you can go to www.remotecentral.com/cgi-bin/codes where a large number of pronto HEX codes can be found which can be converted.
Regards Keith....
