Beo5 for non-B&O audio equipment
jans
Belgium
Posts 394
jans Posted: Fri, Nov 1 2013 6:21 PM
I am thinking of using my BEO5 for controlling my audio equipment (Linn Majik DSM or Marantz amplifier). Is this possible? Where can I find the IR codes for doing this?
Looking forward to hearing experiences from other forum members!
Jan
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
You can control 99% of 3rd party products with the Beo5.
The best way of getting the IR codes for your required 3rd party products is by capturing them from your original 3rd party remote control.
If you wish to control w third party product it is reasonable to assume you have the original remote.
The challenge is then to create an XML control file with these IR codes which is understood by the B&O Control file.
If you cannot capture the required IR codes you can go to www.remotecentral.com/cgi-bin/codes where a large number of pronto HEX codes can be found which can be converted.
Regards Keith....
jans
Belgium
Posts 394
jans replied on Fri, Nov 1 2013 8:48 PM
Keith
Thank you very much for your fast response! Probably a stupid question, but how does one capture a remote's IR commands?
Jan
StUrrock
Posts 995
StUrrock replied on Sat, Nov 2 2013 12:30 AM
the best IR catcher in the business without doubt is the RTI IR-PRO captures virtually anything
Page 1 of 1 (4 items) | RSS
