Mavericks testing - report
elephant
AU
Posts 8,219
elephant Posted: Fri, Nov 1 2013 11:16 PM
I am surprised no one has asked about the latest OSX and iTunes and the status of integration with B&O !
This weekend I had some spare cycles for conducting my own tests.
All tests conducted in a link room via BeoLink Wireless 1 connections through to the BeoPort+MacMin.i
Here's the status:
  • OK: BM-Link - works, played about 20 tracks (mostly ALAC), some use of Beo 4 controls
  • OK: LinkPlayer mark II (i.e. the beta) - works, played 20+ MP3s, used Beo 4 a bit in the beginning - voice feedback working and obviously useful in a link room !
  • OKish - maybe needs more testing: LinkPlayer mark I - works, played 10 plus tracks, used Beo 4 a bit - navigation seemed broken in places (e.g. only yellow and blue key worked; playlist skips [>>] did not work, hand to key numbers)
Both LinkPlayer tests started in a confused state with the Output Device being set to Sunflower rather than the line out - something that requires a remote console to set.
Interestingly the Apple TVs showed up in the Output Device lists i.e. now I have generic airplay support.  I shall have to think about how that might change my music distribution strategy ... presumable Airport Expresses would show up, but what about PlayMakers ?
Overall impression ... BM-Link may have become the easiest to use !
BeoNut since '75
Scott Needham
Paris, France
Posts 217
hello !
i never doubted that you would check it out. ;-)
thanks for the great work and the good news !
- Scott
RobN
Posts 54
RobN replied on Sat, Aug 2 2014 12:23 PM
Hi Elephant,
Really helpful, many thanks.
I'm just looking at upgrading my old MacMini which only runs Snow Leopard to a new faster Mac-Mini which runs Mavericks.
Best,
Rob
lonfred
Posts 200
lonfred replied on Sat, Aug 2 2014 3:21 PM
Thanks a lot for the test. Did you also test if the Netradio function works again with BM-Link?
elephant
AU
Posts 8,219
lonfred:
It's not the best of tests, but I gave it a go.
First N-Radio and from several sources: e.g. link room, BS4, and BV8 and nothing happened.
So I then tested N-Music and the BM-Link worked fine.
While N-Music was running I tried to switch to N-Radio using Beo 4 and a BL 1000 controller - neither caused the system to switch sources.
Now that may mean many things - including that I do not have the correct N-Music playlist set up for N-RADIO
(properly i.e. it is there, but with only 3 stations, which may be stale - however it looked to me that the command was being ignored rather than a station being attempted and then failing)
which as I recall it, is the trick that's required.
So a little test, not perfect, and with perhaps a bad result.
Sorry.
BeoNut since '75
lonfred
Posts 200
lonfred replied on Sun, Aug 3 2014 6:08 AM
Ok. Thanks again. Thats a bit said. Then I still will use the old worksround with a playlist for internet radio under N-music.
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
