I am surprised no one has asked about the latest OSX and iTunes and the status of integration with B&O !
This weekend I had some spare cycles for conducting my own tests.
All tests conducted in a link room via BeoLink Wireless 1 connections through to the BeoPort+MacMin.i
Here's the status:
Both LinkPlayer tests started in a confused state with the Output Device being set to Sunflower rather than the line out - something that requires a remote console to set.
Interestingly the Apple TVs showed up in the Output Device lists i.e. now I have generic airplay support. I shall have to think about how that might change my music distribution strategy ... presumable Airport Expresses would show up, but what about PlayMakers ?
Overall impression ... BM-Link may have become the easiest to use !
BeoNut since '75
Hi Elephant,
Really helpful, many thanks.
I'm just looking at upgrading my old MacMini which only runs Snow Leopard to a new faster Mac-Mini which runs Mavericks.
Best,
Rob
lonfred:Thanks a lot for the test. Did you also test if the Netradio function works again with BM-Link?
It's not the best of tests, but I gave it a go.
First N-Radio and from several sources: e.g. link room, BS4, and BV8 and nothing happened.
So I then tested N-Music and the BM-Link worked fine.
While N-Music was running I tried to switch to N-Radio using Beo 4 and a BL 1000 controller - neither caused the system to switch sources.
Now that may mean many things - including that I do not have the correct N-Music playlist set up for N-RADIO
(properly i.e. it is there, but with only 3 stations, which may be stale - however it looked to me that the command was being ignored rather than a station being attempted and then failing)
which as I recall it, is the trick that's required.
So a little test, not perfect, and with perhaps a bad result.
Sorry.
