Hello,
Can someone advise me how to solve the following.
I cannot key in number 3 or 4 on the programming section of the equipment, other digits are OK.
Meanwhile I can key in these numbers when using the remote control.
Thank you for your feedback
Alain
Thank you for your answer I will check from that side.
OK solved
The PCB was not perfectly mounted at the #3 #4 position, some how a bit away y 1 mm from the glass panel.
