Beomaster 3500 cannot key in digit 3 or 4
Traverso
78230 Le Pecq France
Posts 132
Traverso Posted: Tue, Nov 5 2013 9:05 AM
Hello,
Can someone advise me how to solve the following.
I cannot key in number 3 or 4 on the programming section of the equipment, other digits are OK.
Meanwhile I can key in these numbers when using the remote control.
Thank you for your feedback
Alain
beaker
Posts 761
beaker replied on Tue, Nov 5 2013 10:17 AM
Could it be that the glass panel is starting to come loose (which they all do) and is no longer making contact on the underneath. Try pressing harder and think about removing and resticking the panel.
Traverso
Posts 132
Traverso replied on Tue, Nov 5 2013 10:38 AM
Thank you for your answer I will check from that side.
Alain
Traverso
Posts 132
OK solved
The PCB was not perfectly mounted at the #3 #4 position, some how a bit away y 1 mm from the glass panel.
Alain
Page 1 of 1 (4 items) | RSS
