Hi. I have exactly the same Type Beovision. You have to upgrade it with an HD-kit. Then you can select DVI for using an HD source. Ask your dealer. I have done this and for an HD input, even for 32'' the difference is substantial.
Dimitris-
The DVI sockets on the early Mk1 BeoVision 7 - 32 are always accessible via the 'PC' command on the Beo 4 remote controller. When the Scaler Module is added, you will be able to select HDTV: DVI-I within the connections menu under AV1-AV3.
I think then it was not HD-Ready. So the upgrade kit is mandatory if you want to select DVI as an HD source to AV1-AV4 inputs.
Mk2 was HD-ready from new, so this must be a Mk1 set!
The Secret Alpaca: Mk2 was HD-ready from new, so this must be a Mk1 set!
No. ΜΚ ΙΙ was also not HD-Ready from start (it needs to be upgrated with an HD-kit). Type 9321 is MK II
I stand corrected, my apologies!
DrDimitris: The Secret Alpaca: Mk2 was HD-ready from new, so this must be a Mk1 set! No. ΜΚ ΙΙ was also not HD-Ready from start (it needs to be upgrated with an HD-kit). Type 9321 is MK II
Is there a separate scaler module for TV use? For instance, the screen is capable of showing an HD picture via the DVI input and a PC, but not a TV picture because of the HDCP... Is there a part which upgrades the TV from simply 'HD-ready' to 'HDTV ready'??
The Secret Alpaca: DrDimitris: The Secret Alpaca: Mk2 was HD-ready from new, so this must be a Mk1 set! No. ΜΚ ΙΙ was also not HD-Ready from start (it needs to be upgrated with an HD-kit). Type 9321 is MK II Is there a separate scaler module for TV use? For instance, the screen is capable of showing an HD picture via the DVI input and a PC, but not a TV picture because of the HDCP... Is there a part which upgrades the TV from simply 'HD-ready' to 'HDTV ready'??
Yes, but i am sorry i cannot remember the part number. It is quite expensive (around 450 Euros if i remember correctly).
Also, yes what Ola says is correct. The MK II panel is HD-ready. But to use DVI port you need this kit. Before upgrading i confirm that you have HD menu but DVI is not there. It only can be selected after the upgrade. Hope this sorts it out.
One more question: before upgrading to HD-ready, how can I use the DVI for connecting a PC? Isn't this possible?
I tried to setup AV4 as a PC source but it was not possible to choose DVI.
How do I set up PC with DVI on this MK2 non HD-ready BV7-32?
/Ola
HELLO,
I have à beovision7 MKI and i use a hdury3 for hd.Very good picture .
AS
