How can I find out if a Beovision 7 is HD-Ready?
This post has 15 Replies | 1 Follower
B&Ola
Stockholm
Posts 27
B&Ola Posted: Wed, Apr 11 2012 6:56 PM
Hi
A BV7-32 MK2 type 9321
Is this HD-Ready?
In the connections menu when choosing V-AUX I find HDTV but I can't choose DVI there, only YPbPr?
Is this HD-ready?
Wy can't I choose DVI?
Help needed!
DrDimitris
Greece
Posts 699
Hi. I have exactly the same Type Beovision. You have to upgrade it with an HD-kit. Then you can select DVI for using an HD source. Ask your dealer. I have done this and for an HD input, even for 32'' the difference is substantial.
Dimitris-
B&Ola
Stockholm
Posts 27
B&Ola replied on Wed, Apr 11 2012 7:27 PM
Hi and thanks for replaying!
I also had a 7-32 MK1 and before I upgraded this I was able to choose DVI thrue the AV4 connection via PC.
But I can't remember that I had the HDTV choice in the connections menu before I had it upgraded with the HD-ready kit.
Is it possible to se it in the service menu?
The Secret Alpaca
Somewhere in Europe.....
Posts 46
The DVI sockets on the early Mk1 BeoVision 7 - 32 are always accessible via the 'PC' command on the Beo 4 remote controller. When the Scaler Module is added, you will be able to select HDTV: DVI-I within the connections menu under AV1-AV3.
B&Ola
Stockholm
Posts 27
B&Ola replied on Wed, Apr 11 2012 8:16 PM
The one I was looking at was a MK2 but couldn't choose the DVI from any input (AV1-AV4) even if I choosen PC as source.
DrDimitris
Greece
Posts 699
I think then it was not HD-Ready. So the upgrade kit is mandatory if you want to select DVI as an HD source to AV1-AV4 inputs.
Dimitris-
B&Ola
Stockholm
Posts 27
B&Ola replied on Wed, Apr 11 2012 9:00 PM
Thank you all for sorting this out!
/Ola
The Secret Alpaca
Posts 46
Mk2 was HD-ready from new, so this must be a Mk1 set!
DrDimitris
Greece
Posts 699
The Secret Alpaca:
No. ΜΚ ΙΙ was also not HD-Ready from start (it needs to be upgrated with an HD-kit). Type 9321 is MK II
Dimitris-
B&Ola
Stockholm
Posts 27
B&Ola replied on Wed, Apr 11 2012 9:28 PM
Hi again
The one I was looking at now was type 9321 and a (NEU2) MK2.
But the strange about this one was that it had the HDTV-choice menu but I could never choose DVI, only YPbPr, even if I choosen PC as source when setting up the connection.
I read that early MK2 needed to be upgraded with the HD-Ready kit. But what I remembered the HDTV-choice in the connections menu came together with the HD-Ready upgrade
(DrDimitris: I owned a MK1 before which I referring to earlier)
The Secret Alpaca
Posts 46
I stand corrected, my apologies! Embarrassed
The Secret Alpaca
Posts 46
DrDimitris:
The Secret Alpaca:
Is there a separate scaler module for TV use? For instance, the screen is capable of showing an HD picture via the DVI input and a PC, but not a TV picture because of the HDCP... Is there a part which upgrades the TV from simply 'HD-ready' to 'HDTV ready'??
DrDimitris
Greece
Posts 699
The Secret Alpaca:
DrDimitris:
The Secret Alpaca:
Yes, but i am sorry i cannot remember the part number. It is quite expensive (around 450 Euros if i remember correctly).
Also, yes what Ola says is correct. The MK II panel is HD-ready. But to use DVI port you need this kit. Before upgrading i confirm that you have HD menu but DVI is not there. It only can be selected after the upgrade. Hope this sorts it out. Smile
Dimitris-
B&Ola
Stockholm
Posts 27
B&Ola replied on Fri, Apr 13 2012 6:29 AM
One more question: before upgrading to HD-ready, how can I use the DVI for connecting a PC? Isn't this possible?
I tried to setup AV4 as a PC source but it was not possible to choose DVI.
How do I set up PC with DVI on this MK2 non HD-ready BV7-32?
/Ola
alain6578
Posts 48
HELLO,
I have à beovision7 MKI and i use a hdury3 for hd.Very good picture .
AS
alain6578
Posts 48
HELLO,
AS
Page 1 of 1 (16 items) | RSS
