Does anyone know if i can buy the angled wall bracket for my Beosound5, at the moment it sits flat against the wall. i see now there is some with the angled bracket now. Thanks
When you buy the BS5, the wall bracket with angle is issued with it as one of the options for about 795 Dkr. (about 100+€). The item is listed as number 2193 on the price list with the BS5.
Does the wall bracket with part number 2193 fit both systems, Beosound 5 and Beosound Encore?How can I mount the Beosound 5 flat to the wall? With the original ring that was delivered inside the Beosound 5 packaging?
Hi,I finally decided to mount a standard Beosound 5 to the wall. Currently it sits on its table stand. I have bought a wall bracket (the angled thing) consisting of two parts but no screws. :-(- Which screws do I need for it? 6 pieces.- Is there a PDF / user manual for the bracket?
Keep my fingers crossed for you that it will arrive, soon! Would be very kind from you.
Try to calm down, I know how you feel... Is the tracking number correct? And don't trust the DHL status system! :-)I got parcels where the status still told me, that the parcel was posted by the sender at its local store even when I signed when the parcel arrived at home.
after 2 weeks of traveling the BS5 arrived finaly!
But unfortunately not at my place, but at the senders place. :-(
DHL at it's best! They have bad customer service and I've experienced these stories a few times. DHL claimed I was unknown at the adress and after the second delivery I got the corresponding parcel... very strange. Maybe you can be a little relieved, that you are not the only person that "enjoyed" the great service and capabilities of DHL.Seems your Beosound 5 enjoys traveling... so give it a second chance.
TWG:Hi, I finally decided to mount a standard Beosound 5 to the wall. Currently it sits on its table stand. I have bought a wall bracket (the angled thing) consisting of two parts but no screws. :-( - Which screws do I need for it? 6 pieces. - Is there a PDF / user manual for the bracket?
Glad to hear that it finally arrived. Did it arrive well?Thank you for the information. Do you have the angled bracket or how did you mount it?I have this one (angled): http://sound-affair.com/beosound-5-encore-angled-wall-bracket
Thank you for your answers. I've still not found a manual from B&O explaining the angled wall bracket... :-(Here's a thread about upgrading the Beomaster to SSD you are looking for:http://archivedforum2.beoworld.org/forums/t/22109.aspx?PageIndex=1
