I have an issue with my beautiful white 5500 turntable. When it is plugged in to the mains, the motor starts on its own. It won't stop spinning unless I unplug it from the mains...
I'm hoping it's an easy fix, as it is in excellent condition. Can anyone help???
x:________________________
A stuck button or internal switch ?
What happens if you put a record on and try a full play cycle? Once the LP is finished does it continue to spin or stop?
Does sound like a stuck button. Give them a good few pushes to see if it releases anything.
Dave.
