Beolab 5 ...extension cord
This post has 3 Replies | 2 Followers
Maab
Posts 95
Maab Posted: Fri, Apr 13 2012 8:57 PM
Hello,
The beolab 5 do have a power cord that doesn't go far enough for me.
Is it good idea to add an extension cord or one of those common surge protectors?
Thank you
M
KingOfSnake
Posts 162
I would advise buying a longer power cord (they are freely available)................ and put a surge protector on it at the end rather than using an extension.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hello Maab,
Welcome to the forum!  Power cords are generally available in a range of lengths up to 10 metres (approx. 35 feet).  As King of Snake says, you should always go for a single length of lead instead of using extensions where possible.
If you need any help finding suitable cables, please feel free to ask.
Kind regards,
Steve.
www.soundsheavenly.co.uk
Steve.
www.soundsheavenly.com
Maab
Posts 95
Maab replied on Sat, Apr 14 2012 1:15 PM
Thank you for the suggestion.
M
Page 1 of 1 (4 items) | RSS
