we have had a powercut yesterday and when the power came back our beosound 4 went to standby instead of asking for the passcode. Now the device cannot be switched on again - neither on the device itself nor with a remote control. We tried unplugging it again for a couple of minutes but that didn't help either?
Any advice is highly appreciated!
Thanks!
A Very Warm Welcome to Beoworld.
You say the unit is in standby, but is the Standby light flashing or on all the time ?
Regards Keith....
Thanks Keith,
The red light is on all the time.
The glass slides up but the display does not come on, nor does the cd, radio or mem work.
Sparkford76:The glass slides up but the display does not come on, nor does the cd, radio or mem work.
BeoNut since '75
Thanks for the idea. Unfortunately, it does not work either.
Does it respond to an A option instruction. Does the standby led flash once.
Hi Buddy, the standby light does not flash at all. It comes on as soon as i plug in the device and it stays on. What is an a option? It doesnt show the clock nor does it respond to a mem.
No more Ideas? ;-(
Just to let you know... 700 euros got me a new circuit board and we are up and running again.
thanks again for all your help.
Hi
I have the exact same problem do you know which circuit board was replaced ?
