Bv11 or keep Bv7-40 MK3
This post has 38 Replies | 2 Followers
quader
Posts 109
quader Posted: Sun, Dec 1 2013 5:55 PM
Hi
B&o are offering £1300 against bv11 46" and wondering what you guys advise I also have a cinema setup with a third party projector using speaker roles and enjoy watching
Should I upgrade?
Millemissen
Flensborg, Denmark
Posts 14,680
No, why?
Chris Townsend
Qatar
Posts 3,531
Yes. The picture on the 7-40 mk3 is very much a first generation full HD picture, very dark with little detail.
When I upgraded from the 7 to the 10 it was a significant pictorial upgrade. The 11 in most ways, not all, is better again. The speakers and their modes etc, compared to the 10 are a large upgrade. I know you have speakers etc, but most of the time as a standalone TV it's very good.
The Spotify and YouTube integration is a clever and useful smart TV upgrade.
SHEFFIELD
Posts 262
Hi Quader,
Are you using the 7-40 system 3 to drive the projector using your existing speakers?
Nick
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sun, Dec 1 2013 8:00 PM
Yes, I'd upgrade in a heartbeat if funds permitted!
I have to say the 7-40 Mk3, even by the very latest standards, is a superb TV - but the BV11 is right at the cutting edge...
Lee
Seanie_230
UK
Posts 2,278
Hi there
if you are like me and running your Beemer from the BV7 then my moving to the new TV you will loose the second output to the Beemer.
This is the reason I have not upgraded my tv and that I am stuck between a rock and a hard place.
bv7 mk6 will allow us to keep the 2nd output and I believe that the beosystem 4 is not yet capable of doing it but should be in the future.
Hope this helps
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
quader
Posts 109
quader replied on Sun, Dec 1 2013 9:10 PM
Hi Seanie
i got the impression i could connect all my present setup  onto the bv11 as there appears to be lot of connections  on thr bv11
i too have an optoma hd65
SHEFFIELD
Posts 262
If you drive the projector etc via your 7-40, then you won't be able to do this via BV11
Millemissen
Flensborg, Denmark
Posts 14,680
My short answer was "No", because you said that you use the (BSys3 of the) BV740 MK3  as a center for your cinema setup.
I agree with Chris that the BV11 is superieur to the BV7 in most ways, but you would loose exactly that function as things are now.
Would be wise to wait untill the 'promised' cinema solution for the BSys4 has arrived. Maybe new constallations will be possible then - or perhaps with the awaited new BV coming next year?
I am sure there will be good offers later as well for those who want to upgrade.
moxxey
South West, UK
Posts 5,359
moxxey replied on Sun, Dec 1 2013 10:00 PM
quader:
Should I upgrade?
I owned a MK3 and then a MK4. The MK3 is quite old now. My MK4 was a significant picture upgrade and the BV11-46, an even bigger jump. You'd notice a huge difference and, let's face it, your TV experience is primarily about the picture quality, first and foremost.
Obviously the projector issue is a significant reason why you couldn't switch to a BV11, though. Have you considered a BV7-55 MK2? You get a top notch picture, projector support and it shouldn't be much more than upgrading to the BV11.
One word of advice though - sell the BV7 privately, trade in any working a TV you can find to get the £1300!!
Chris Townsend
Qatar
Posts 3,531
Can't you run a projector from a PS3?
Moxxey is correct about the 7-55, still the best TV available and some of the Mk1 versions are quite a bargain at the moment.
Millemissen
Flensborg, Denmark
Posts 14,680
A 'cinema solution' was promised for the BSys4 "by the end of the year".
If this includes the BV11 as well, I don't know.
Maybe it is time to start asking the dealers for this - when, how and how much?
BeoMegaMan
Posts 601
The hardware is available now from Atlona. The SW is what we are waiting on atm.
Ah, you know... A little B&O here, a little there
Millemissen
Flensborg, Denmark
Posts 14,680
@BeoMegaMan
Could you be a bit more specific about the 'Atlona hardware'?
Will it be a BSys4-only solution?
BeoMegaMan
Posts 601
It will work off the AT-HD-IR series and the AT-HD-RSNET. I don't believe there is a B&O only version for the solution.
Millemissen
Flensborg, Denmark
Posts 14,680
Thanks.
"Will it be a BSys4-only solution?" means - will this solution work for a BV11, or only for the 'standalone new engine' BeoSystem 4?
BeoMegaMan
Posts 601
One would believe it's only for the BS4 ATM seeing as the 11's don't have a HDMI out. Weather or not that will change in the future I'm not told ATM.
Millemissen
Flensborg, Denmark
Posts 14,680
You will have to get the video signal out of the BSys4 to distribute it to the projector - but how?
How do you connect these  - I see no HDMI-out on the BSys4.
BeoMegaMan
Posts 601
There is a single HDMI out on the BS4. Apparently, there is another splitter box that hasn't been announced yet that will allow you to do two screens at once.
quader
Posts 109
quader replied on Mon, Dec 2 2013 6:47 PM
i dont know whether you can through a PS3
i know with my present setup i can watch sky channels on the projector as well as blue ray via ps3
SHEFFIELD
Posts 262
Are you driving the projector from the TV via the cinema control?
quader
Posts 109
quader replied on Mon, Dec 2 2013 8:56 PM
Mk3 has 2 output options
Marco6474
Posts 54
I received my BV 11-55 last week but kept my old BV 7-40 mk3 for my bedroom. I'd just like to say GO for it!
The picture is so great and can't be compared (and even the sound). There are so many HDMI inputs and possibilities that you'll find a way to use a projector, should you still want to use it...
I'd just advise to get a MK2 rather than a discounted MK1 for the wireless capability. It offers such flexibility. With the speaker group options, you may even use it like we did with the former Masterlink.
Hope that helps, Marc.
quader
Posts 109
quader replied on Mon, Dec 2 2013 10:12 PM
I am tempted Bv11 -55 is too big for my room and Hence I invested into a HD projector
There is not a solution to use both unless someone out there has a solution
Chris Townsend
Qatar
Posts 3,531
Oddly enough I was speaking to someone tonight who has just replaced his 7-40 Mk 6, with an 11-55.
Much of what he watched on DVD SD, was of a better quality on the 7-40 Mk 6 than his new 11. He has speakers so the audio side is largely irrelevant.
moxxey
South West, UK
Posts 5,359
moxxey replied on Mon, Dec 2 2013 11:18 PM
Chris Townsend:
Always been that way. SD is filmed with only 576 lines (480 for NTSC), so pixels are doubled on a 1080p panel. The larger the panel, the more obvious are the flaws the the original recording. So on a 55", SD will look terrible. It looks poor on my BV11-46, but fine on my BV10-32. I barely see much difference between SD and HD on the 32", due to the size of the pixels on the small panel. HD is marginally sharper.
Why do you think they recommend 4K for 55" or higher? :)
Chris Townsend
Qatar
Posts 3,531
It's all so blindingly obvious now my world isn't in a Rose induced cloudErm..
TerryM
Posts 66
TerryM replied on Tue, Dec 3 2013 4:58 PM
moxxey:
Chris Townsend:
I have to disagree about SD necessarily looking terrible on a 55".
The quality of the processing will have an important bearing on the quality of the displayed image.
SD, be it Freeview, or DVD, was excellent on my Pioneer 60" TV, and is superb on my BV 7-55 Mk 2.
As for 4K, the reviews of currently released TVs are revealing them to have issues re non 4K PQ.
quader
Posts 109
quader replied on Tue, Dec 3 2013 5:57 PM
How much is the Bv11 -55?
badgersurf
Posts 539
Does the BV11 upscale pictures and sound from a DVD?
SHEFFIELD
Posts 262
I've sent you a pm....such a good deal that I daren't broadcast it!
And in stock....
Mark
London
Posts 1,063
Mark replied on Tue, Dec 3 2013 9:11 PM
I don't want to detract from the quality of this good discussion but age has to play a factor with enjoying great picture quality. There has to be an optimum age of a person where they can view or hear at the highest level.
I aspire to own the newest and best but question if I would really get all the benefits apart from knowing I have purchased the best.
moxxey
South West, UK
Posts 5,359
moxxey replied on Tue, Dec 3 2013 9:57 PM
TerryM:
Normally SD is better on a plasma as it smooths the picture. An LCD is far more 'brutal' with the source, so any flaws are exaggerated.
It stands to reason that SD isn't great on a large LCD screen as it has to be both upscaled and you see the flaws in the recording. It's true that some modern well-produced SD still looks good on a large LCD panel (as an example, a recent movie), but older SD or SD through a low bandwidth channel, doesn't look good, as the source isn't good to start with. You can see quite clear and obvious differences between even high bandwidth SD content and the same channel in HD.
There's simply no way a 576-lined SD image is going to be 'superb'. I can't think of any SD content on a BV11-46 (only slightly being a 55-MK2 in picture quality) or my BV7-40, that I'd regard as superb. There's a reason that 1080p Blu-ray looks so good on a 55" panel, and it's not down to picture processing. That's more of a dream B&O owners like to tell other people to justify their purchase, IMHO. Note the last word there.
quader
Posts 109
quader replied on Wed, Dec 4 2013 6:09 PM
for sure HD content is so much better than SD, must look good on the BV11 if it is better than
BV7 Mk3 , i enjoy watching HD content either through Sky or PS3 and very rarely use
the built in DVD player for that reason.
4K is suppose to be even better than HD but i think we are still few years off when more content
is available in 4K
BeoMegaMan
Posts 601
The software for the dual screen experience on the BeoSystem 4 is now available from B&O. You will need specialty Atlona pieces as well as having to contact B&O to have them specifically send you the update to your BeoSystem 4. Apparently it's not a SW that will be rolled out to every machine. All those holding out for dual screen contact your dealer now!!
3rd party products -> HDMI Matrix/Exp./Ext. -> Atlona HDMI Switch/Expander- AT-HD4-V42-B&O
Millemissen
Flensborg, Denmark
Posts 14,680
@BeoMegaMan
why not make a seperate post about this awaited sw-update?
I saw your posting only 'by accident'.
Might interest more BeoWorlders.
BeoMegaMan
Posts 601
Your right.... I was just trying to keep it in the context of the question. I'll make another post specific to the announcement.
quader
Posts 109
quader replied on Fri, Dec 13 2013 1:35 PM
To add beosystem 4 and other accessories all seem to much of an expense
Shame that B&O have not thought of this
BeoMegaMan
Posts 601
I think B&O did think it through. Would you rather buy a Beosystem 4 with everything baked in and pay twice the price? Or buy a basic model for half the price then add the features as you need them or desire? Something like 1-5% actually use the dual screen setup, so should we all have to fork out for those few to take advantage? Also, those parts are from Atlona not B&O so you have the potential to shop around or come across a deal/bargain. Jmho :)
Page 1 of 1 (39 items) | RSS
