I've just bought a Beo1 remote for my Beocenter 1 which I operate with a Beo4. Another remote was obviously not essential but Beo1 has been always a desirable icon to me. However my new Beo1 does not work with the Beocenter 1. Only the OFF button works and after testing the IR light (using a digital camera) all buttons appear to be emitting IR.
I'd appreciate your advice, please.
Regards
Joan
I think the beo1 only controls the earlier versions of the bc1/bv1 , as I to got one and it wouldnt work on any of my bc1/bv1 and now use only the beo4.
That was what the dealer informed when I called them with the same issue, you will have to chi the age of your bc1
Hope this helps
Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Thanks bramble
I think it is going to be more a decoration object rather than a remote . Anyway. it looks fantastic beside my Beosystem 4500.
Agree with bramble. Earliy BC1s worked with Beo1 (as standalone products). Later BC1s were made for Beo4.
But maybe you want to "convert" your Beo1 into a Beo4.
These threads in the old forum might help.
http://archivedarchivedforum2.beoworld.org/forums/t/29071.aspx?PageIndex=1
And: http://archivedarchivedforum2.beoworld.org/forums/p/13515/309934.aspx#309934
Stefan
Thanks Stefan
I am trying to open both links unsuccesfully. The first link redirects me to a similar question about Beo1 and the second one does not exist anymore. How can I open them?
regards
Strange. both links work for me...(?)
But I just copy the quintessence of the german link here:
"Hallo zusammen,
ich habe mir eine Beo1 aus der Bucht ersteigert. Als Sammlerstück in der Vitrine prima, aber funzt nur mit dem BV1.... Das kann geändert werden!! Anleitung: 1. Die Tasten Display,Stby und Stop GLEICHZEITIG drücken und loslassen. 2. Die Taste Stop drücken und halten, dann Doppelpfeil rechts drücken und beide Tasten loslassen. 3. Taste Display drücken und loslassen. Fertig! Jetzt können alle Beo4-tauglichen TVs bedient werden. PS: Einschalten mit GO!" My Beo1 works exactly like a Beo4 after this procedere. Hope this helps. Stefan
Anleitung:
Fertig!
Hope this helps.
thanks again stefan. I've tried these instructions but does not work. Any idea?
Reread the whole thread in the first link.
did you try the battery "trick"?
Some people got it working that way....
Thanks stefan. Finally I managed to open the link and read it.
Tried the battery trick but nothing happened. Anyway, I'll have to accept it ) and keep on trying from time to time.
By the way, what's the logics and explanation of changing the IR beam and the remote's software by simply pressing different keys simultaneously?
