Anyone recognise these drivers?
This post has 5 Replies | 0 Followers
Premiumverum
Netherlands
Posts 115
Premiumverum Posted: Thu, Dec 12 2013 1:31 PM
Seller says they are B&O, tweeter looks like it's from a beolab 6000 or 8000. The woofer, I don't know! And that little grille and capacitor... ?!
Are these B&O drivers?
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Dec 12 2013 1:55 PM
The metal shrouding on the rear of the speakers points to Avant for me..
Not sure what those grilles are for though!
Lee
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Dec 12 2013 2:26 PM
The metal shrouding indeed suggests that they are magnetically protected drivers from a TV. In addition to some Avants, those same kind of tweeters are used in AV9000 and MX7000 so these could be from there. I have no explanation for the grilles, though, and the caps look like some fancy pansy audiophile caps instead of bog regular bipolars that B&O tends to install...
--mika
Premiumverum
Netherlands
Posts 115
Magnetically shielded? Learning new stuff all the time. I checked the Avant service manual, they look just like the ones in the drawing there. Tweeters are a different part number from the beolab tweeters.
The caps looks like F&T electrolytics, these are rather small bipolars with raw foil.
And the grilles, maybe for some kind of bass port.
Thanks for the assistance guys!Big Smile
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Thu, Dec 12 2013 3:34 PM
And you'd only need a shielded speaker on a tube TV, flat panels don't have the magnetic field issue CRTs did.
Jeff
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Dec 13 2013 9:27 PM
What's the diameter of the woofer? BL6000 are 9 cm (but aren't the same as these) . MX 7000 has 9 cm.
Avant/BV5 have 10 cm.
My guess is they are from a avant. The shape of the chassis looks the same.
Page 1 of 1 (6 items) | RSS
