Hi all,
Sorry posted this in the wrong section previously!
After playing a cd earlier, the carriage/laser dropped suddenly to the base position and wont return to the home/top position. Is this a common problem? will it be easy to get repaired? expensive?
It might be as simple as cleaning the finger protection sensors - look for two small, clear things that stick out from opposite ends of the metal surface near the open side of the glass door. Wipe gently with a clean, soft cloth, and that could be it.
Stan
Stan,
Your a star, I now feel really stupid as that did the trick, so pleased
Very attentive cleaning from now on!!!
Many thanks :D
Mine did the same thing a few years ago. Unfortunately that was before I knew about Beoworld but after the local store closed, so I wound up taking it 60 miles to a repair shop to find out it just needed the prisms cleaned.
Jeff
