Beocord 5000 & 5500
ouverture
London
Posts 263
ouverture Posted: Tue, Dec 17 2013 12:01 AM
I have a 5000 and my Dad has a 5500, they are fine cassette players, but is there a proper way to clean them. When I had a Sony deck years ago there was a "cleaning mode" button, and this made cleaning the capstans, heads and pinch rollers much easier, it is not the end of the world, I was just looking for advice as there does not seem a lot to clean when you look inside the Beocord !
nb.
am still using cotton buds and 91% Isopropyl on the advice of a B&O shop about 20 years ago just dabbing what I can visibly see
nbb
fortunately we do not have to worry about demagnetising heads, as all Beocords (except I believe a few in the early seventies) demagnetize themselves when turned off, a good enough reason to turn off the complete system 2 or 3 times a year :-)
MediaBobNY
Greenwich Village, NYC
Posts 1,106
MediaBobNY replied on Tue, Dec 17 2013 12:44 AM
I use Q-tips dampened with rubbing alcohol (which is 70% isoprpyl) in conjunction with one of these.   And don't use alcohol on the pinch rollers - it will dry them out.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Dec 17 2013 6:12 AM
Beocord 5500; Hold stop while pressing play and the heads etc. will engage without a tape loaded.
Pressing turn will switch direction, allowing you to easily clean both pressure rollers.
Press stop when done.
Manbearpig
Posts 908
Hi everybody,
since I'm one of those still using Beocords, I'd like to jump in. Which type of IPA is best to use? 70%? 100%? Does your "trick" only work with the Beocord 5500, or with the Beocord 7000 as well? I'll have to clean my 7000 soon and don't want to make any mistakes.
Thanks!
Kai
Anders Jørgensen
Denmark
Posts 350
Thank you for the tip Martin!
It works on 5500 and 6500. Just checked.
ouverture
London
Posts 263
ouverture replied on Thu, Dec 19 2013 8:38 AM
Dillen:
Beocord 5500; Hold stop while pressing play and the heads etc. will engage without a tape loaded. Pressing turn will switch direction, allowing you to easily clean both pressure rollers. Press stop when done. Martin
thanks Martin, that is great
NB. only use 91% or 100% was the B&O advice, because any less than that and you have too much water content and that is the last thing you want in splashing around in your deck, with 91% it practically dries as you clean with the tips
ouverture
London
Posts 263
ouverture replied on Fri, Dec 20 2013 9:01 AM
Manbearpig:
Kai, use 91 or 100 IPA
try the 7000 and let us know, it cannot do any harm to try :-)
cheers
Peter
Page 1 of 1 (7 items) | RSS
