Dear members,
what are the differences between the various Beocenter 1 types? I understand that earlier models use the Beo1, whereas later models use the Beo4. What were the relevant options (Accs)? Did Masterlink ever become a standard? What about the surround module? Was this module only available as an option? Is it the same as the one in the Avant? Which configuration of the Beocenter 1 is most desirable/do you like best?
Thanks!
Rgds,
Kai
Thanks. I was reading that not all of the Beocenters had Masterlink. However, as far as I understand, differences are mainly in options but not in anything that affects picture and sound quality. Therefore, picture and sound quality should be the same across all different types of Beocenter 1s. It's only connections that vary? Is that correct?
