The Blu Ray Player in my beovision 7-55 ( Feb 2011)has stopped playing some new blu ray discs
The blu ray discs play on my PC and other very new panasonic (march 2012) blu ray player in my sons bedroom?
how do i fix this, is there a firmware download available?
Your B&O dealer will fix this. 2 year minimum warranty and more you can expect as service. (See also the law for consumer rights......)
You can update your bluray player by yourself!
thats great news...how do i update the bluray ?
I am not sure you can update the firmware for the Blu-Ray Player.
The only firmware I can see on B & O's website is for the DVB Tuner.
You should check with your local dealer if a firmware update for the player has been issued.
If you have an ethernet cable plugged into your BeoVision7 you can update the bluray software on line. You don't need a service engineer for this.
Opman
I am interested in doing this as well. Could you supply more detail as to exactly how you go about it. I have a 7-40 mark iv
Opman: If you have an ethernet cable plugged into your BeoVision7 you can update the bluray software on line. You don't need a service engineer for this.
Alternatively, your dealer can give you the firmware on a CD, as far as I can remember. This enables you to insert the CD and upgrade the firmware, if you do not have ethernet internet access close to your TV.
I had the same issues as you (some recent Blu-rays wouldn't play in my BV7) and this was fixed in a drive firmware update. However, luckily for me, my dealer agreed to do the install and upgraded the TV sw at the same time.
Thanks Moxxey
interestingly i also contacted B&O direct who were very unhelpful but i'll contact my dealer now
