Recommended passive speaker for BeoCenter 9000?
Piaf
Victoria, British Columbia Canada
Posts 2,639
Piaf Posted: Fri, Jan 3 2014 3:44 AM
I see that the recommended speaker for a BeoCenter 9000 is the RL 60. I have not heard a lot of good things about the RL series, so what would be a good match in a passive speaker?
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century,  S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase,  B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Jan 3 2014 10:46 AM
I would say that RL 60.2 is a perfect match for BC9000. They matches time, design, power handling and they sound wounderful.
//Bo.
A long list...
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Piaf:
Jeff
I don't know who you have been listening to but in my opinion there is very little wrong with a pair of RL60.2's when used with the Beosound 9000.
Regards Graham
tournedos
Finland
Posts 7,357
joeyboygolf:
(You of course mean the Beocenter 9000, Graham!)
Same here. I have a pair of RL60.2s in the office, run by a Beocenter 8000 (same amp) and I'm very happy with the combo after I recapped the speakers. It's not a party setup simply because the Beocenter doesn't have that much power, but within its limits the setup sounds great.
You can also try RL6000s (newer, slightly updated model of the same speaker) but steer clear from RL60s (without the .2) with their rotted off bass radiators.
--mika
joeyboygolf
Posts 4,188
tournedos:
joeyboygolf:
My mistake, of course BeoCENTER 9000
Regards Graham
Piaf
Posts 2,639
Piaf replied on Fri, Jan 3 2014 4:36 PM
joeyboygolf:
Piaf:
Jeff
Hi Graham,
I had to think about that for a moment and having remembered the source of the negative comments on the RL series, I have good reason to not only “consider the source,” but to actually consider the rants and tirades discredited.
Jeff
the_o_master
Posts 856
Piaf:
Jeff
I am using the Beovox 3000 (Flat Panel) speakers with my BC9000 and I can say they sound very, very good. But if you are fan of deap Bas than they are not for you...
BR,
Theomaster
Vintage Bang & Olufsen
Piaf
Posts 2,639
Piaf replied on Sat, Jan 4 2014 12:35 AM
the_o_master:
Piaf:
Jeff
BR,
Theomaster
I thought it best in order to get a real open dialog; to simply ask the question while omitting the reason for the question. Does that make any sense?
Anyway, I have the option of using either S 45.2 or S 75 speakers with my BC 9000 and because I AM (admittedly) a fan of a lot of bass, I chose the S 75’s.
This choice allowed me to use the S 45.2 speakers with my Beomaster 2400, which is a great pairing.
However while reading various posts vis-à-vis proper matching of amplifier to speakers; it occurred to me that the S 75’s might be a bit of a stretch for the 30 to 40 watt BeoCenter.
Jeff
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Piaf:
Think outside of the box.  Use any make/model of speaker you like.  I drive a pair of award-winnng PSB Mini Stratus's (in piano gloss black on stands) with my Beosystem 6500.  Perfectly pleased with the pairing.
Page 1 of 1 (9 items) | RSS
