Question about cables for Beolab Penta II Type 6623 to 6500 Series system
This post has 6 Replies | 0 Followers
dubblewubble
Posts 8
dubblewubble Posted: Fri, Jan 3 2014 5:20 PM
Hello!
Let me first introduce myself. I am a male from Massachusetts who has been given a Bang and Olufsen 6500 Series system with two Beolab Penta II Type 6623 speakers. However, the owner did not give me the 4 Pin speakerlink cables because they were routed all through the house and would be needed some deconstruction to remove.
I was reading a setup guide for the 6500 series system and it said that Powerlink cables should be used to setup active speakers like the Penta's. Does this hold true for the Penta II Type 6623's as well? The previous owner used the 4-pin speakerlinks, so I want to make sure that if I use the Powerlink cables made for Beolab Penta MkII's, I won't lose display power or anything like that.
I appreciate any help!
Regards,
Melvin Glover
Beofile7
Posts 150
You can use either. I used 4 pin DIN plugs for years and considered it had more of a punch but powerlink is also fine. All the display functions are still there regardless.
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Jan 3 2014 6:34 PM
Just be sure to use a fully wired powerlink cable!
If you go for powerlink cables.
Ralf
dubblewubble
Posts 8
Thanks, Beofile7!
Thank you, kallasr, what does "fully wired" mean?
dubblewubble
dubblewubble
Posts 8
Nevermind! Just found out that "fully-wired" refers to the MkII and MkIII powerlink cables. Thank you guys!
BO
Halmstad, Sweden
Posts 728
BO replied on Fri, Jan 3 2014 8:21 PM
dubblewubble:
Only MKII. MkIII are not fully wired.
//Bo.
A long list...
dubblewubble
Posts 8
True! Good thing you mentioned that before I ordered. Thanks!
Page 1 of 1 (7 items) | RSS
