Controlling amp power through Powerlink
beopaul
Posts 83
beopaul Posted: Wed, Apr 18 2012 3:05 PM
I'm using a non-B&O amp with a Beolink Active, and would like the amp's power to be switched on/off automatically by Powerlink. Any suggestions?  I could build my own box with a relay connected to the appropriate Powerlink signal, but would like to avoid this if possible.
--Paul
Evan
USA
Posts 3,621
Evan replied on Wed, Apr 18 2012 4:03 PM
There is a unit made by Niles, the AC-3 that does what you want. But it depends on the powerlink trigger power, it has to be a minimum of 100ma to actuate this particular switch. Does anyone know what the exact amperage is on a powerlink trigger?
There is also the official B&O mains switch, which is designed for use with powerlink. Member Jeff has a thread going on one of these but I haven't been able to keep up with it! I'm sure he has covered all relevant info regarding this switch in that thread.
If you end up building one, show it off! I would like to see it Stick out tongue
Beo4 'til I die!
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Apr 18 2012 7:30 PM
Evan:
Certainly less than 100 mA. That's a huge current to use for this purpose! Is the box running a relay directly off that or what?
A typical Beolab will need less than 1 mA to turn on. Dunno about Beolink Active, but a typical Beomaster certainly won't like you drawing anywhere near 100 mA from the Powerlink "on" signal.
--mika
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Apr 19 2012 10:08 AM
Is this what you are looking for?
http://www.beoworld.org/beotech/circuit.htm
beopaul
Posts 83
beopaul replied on Wed, Apr 25 2012 10:19 PM
guyowen:
yup, pretty much if I do my own, plus a box to house it with all the required connectors. THanks for the link While I'm at it, I'd probably add a secondary audio input circuit since my Beolink Active box is old enough to not have an aux/PC input.
-- Paul
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Apr 25 2012 10:23 PM
Note that the circuit is a bit silly - just use a relay with a coil rated for whatever supply voltage you have available, and you can omit the voltage regulator along with the caps around it.
I.e +12V supply -> 12V relay -> all you need is the transistor, its base resistor and the diode.
--mika
Page 1 of 1 (6 items) | RSS
