I'm using a non-B&O amp with a Beolink Active, and would like the amp's power to be switched on/off automatically by Powerlink. Any suggestions? I could build my own box with a relay connected to the appropriate Powerlink signal, but would like to avoid this if possible.
--Paul
There is a unit made by Niles, the AC-3 that does what you want. But it depends on the powerlink trigger power, it has to be a minimum of 100ma to actuate this particular switch. Does anyone know what the exact amperage is on a powerlink trigger?
There is also the official B&O mains switch, which is designed for use with powerlink. Member Jeff has a thread going on one of these but I haven't been able to keep up with it! I'm sure he has covered all relevant info regarding this switch in that thread.
If you end up building one, show it off! I would like to see it
Beo4 'til I die!
Evan:But it depends on the powerlink trigger power, it has to be a minimum of 100ma to actuate this particular switch. Does anyone know what the exact amperage is on a powerlink trigger?
Certainly less than 100 mA. That's a huge current to use for this purpose! Is the box running a relay directly off that or what?
A typical Beolab will need less than 1 mA to turn on. Dunno about Beolink Active, but a typical Beomaster certainly won't like you drawing anywhere near 100 mA from the Powerlink "on" signal.
--mika
Is this what you are looking for?
http://www.beoworld.org/beotech/circuit.htm
guyowen:Is this what you are looking for?http://www.beoworld.org/beotech/circuit.htm
Note that the circuit is a bit silly - just use a relay with a coil rated for whatever supply voltage you have available, and you can omit the voltage regulator along with the caps around it.
I.e +12V supply -> 12V relay -> all you need is the transistor, its base resistor and the diode.
